Disable the Simple Loop Protection Protocol (SLPP) Guard feature.
slpp | Specifies disabling SLPP. |
guard | Specifies not using the SLPP Guard feature, which disables a port as soon as an SLPP PDU is received. |
ports | Specifies selecting ports on which to disable SLPP guard. |
port_list | Selects which ports on which to disable SLPP guard. |
all | Specifies disabling SLPP guard on all ports. |
By default, SLPP Guard is disabled on all ports.
SLPP is an application that detects loops in a Split Multi-link Trunking (SMLT) network. SLPP Guard is a complementary feature that helps prevent loops in networks by administratively disabling an edge port if a switch receive an SLPP PDU from an SMLT network.
The following example disables SLPP Guard on port 5:
# disable slpp guard ports 5
This command was first available in ExtremeXOS 30.2.
